Owell2FollowerAug 28, 2024Re: rs700so you cant disable an or turn off any of th wifi? there no butten
1 ReplyReplies sorted by OldestFURRYe38Guru - Experienced UserAug 28, 2024You can disable the wifi radios using the routers web ui settings. Under Advanced Tab/Advanced Settings/Wireless Settings
