jaimea
Jun 22, 2026Follower
Starlink Router
I bought a Netgear Nighthawk RS300 to be used with Starlink. I viewed a video that showed that you may not use the Starlink router and connect your own router directly to the Starlink power base and...
CrimpOn
Jun 22, 2026Guru - Experienced User
jaimea wrote:I viewed a video that showed that you may
There do not appear to be many Starlink customers visiting the Community Forum these days. The odds of someone reporting their experience might be small.
What happened when you did what the video suggested?
