William3087
Aug 07, 2025Aspirant
Update doesn't fix the upload speed i have 2gig speed symmetrical
this update doesn't fix the upload speed i have 2gig speed symmetrical and when i do a speed test with ookla speed test app i get 300mbps max
BH_C
Aug 07, 2025NETGEAR Expert
Yes, William3087 , can you run speed test from the Nighthawk App or the router's Web GUI? this is to isolate the issue and check the max speeds between the RS500 and the ISP side first.
and what is your RS500's firmware version?
