fab723
Feb 02, 2025Aspirant
Rif.: Nighthawk Rs200 - no WIFI after Reboot - Internet via LAN ok
Same issue here. I'm dealing with RS200 and firmware v1.0.1.60, and every time I reboot the router (by detaching the electrical plug), the WiFi disappears and the only way to make it work again is a ...
Feb 03, 2025Guru - Experienced User
Recommend you open a support ticket regarding this and see if support can help you out. Might ask about an RMA.
