Cap1tan5
Feb 24, 2025Tutor
Rif.: Nighthawk Rs200 - no WIFI after Reboot - Internet via LAN ok
I have the same problem. After a few weeks of working fine, the product suddenly started losing 3 packets after every 10 successful ones, and it just keeps doing it. I got a new product after speaki...
Cap1tan5
Feb 24, 2025Tutor
I have a Gofiber bridge (I got it from my ISP) but it is fine. when I switch to my old Cisco router this problem disappears and I can only see it using my Netgear RS300.
I connected via CAT6A LAN cable.
I have my smart TV and phone connected to it.
It happens on everything that is connected to the router no matter the network, LAN cable connection or wifi. It behaves the same for all of them.
i try both to disable and enable the protection engine but I get the same behavior.
I do not have Armor or IPv6 or any other feature.
I have made a factory reset when it was updated on version 1.0.1.60 but not since 1.0.1.74
Feb 24, 2025Guru - Experienced User
Might give one more factory reset and see. If not, I'd make contact with NG support about this.
- Cap1tan5Feb 25, 2025Tutor
so i have made a factory reset and it worked fine for the first 15 minutes. after that I started to see the same problem again.
Hardware Version RS300Firmware Version V1.0.1.74
GUI Language Version V1.0.0.451
Protection Engine Version 2.2.214.4/1.0.0.2112
Operation Mode RouterCPU Load CPU1: 9.09% CPU2: 8.08% CPU3: 5.10% CPU4: 8.00%
Memory Usage (Used/Total) 638MB/1999MB
Flash Usage (Used/Total) 423MB/512MB
