Cap1tan5
Feb 24, 2025Tutor
Rif.: Nighthawk Rs200 - no WIFI after Reboot - Internet via LAN ok
I have the same problem. After a few weeks of working fine, the product suddenly started losing 3 packets after every 10 successful ones, and it just keeps doing it. I got a new product after speaki...
Feb 24, 2025Guru - Experienced User
Might give one more factory reset and see. If not, I'd make contact with NG support about this.
Cap1tan5
Feb 25, 2025Tutor
so i have made a factory reset and it worked fine for the first 15 minutes. after that I started to see the same problem again.
Hardware Version RS300
Firmware Version V1.0.1.74
GUI Language Version V1.0.0.451
Protection Engine Version 2.2.214.4/1.0.0.2112
Operation Mode Router
CPU Load CPU1: 9.09% CPU2: 8.08% CPU3: 5.10% CPU4: 8.00%
Memory Usage (Used/Total) 638MB/1999MB
Flash Usage (Used/Total) 423MB/512MB
