CK36
Aug 11, 2025Guide
Router dropping internet frequently
RS280 running v1.0.1.90 The problems I'm having are frequent (typically daily) but are often different so it's a little hard to troubleshoot. Here are the types of issues I encounter: Users (2 of ...
Aug 11, 2025Guru - Experienced User
Try reverting FW back to prior working version.
What model NG modem do you have?
Might check with NG support to see if there is a beta FW available to try.
