CK36
Aug 11, 2025Guide
Router dropping internet frequently
RS280 running v1.0.1.90 The problems I'm having are frequent (typically daily) but are often different so it's a little hard to troubleshoot. Here are the types of issues I encounter: Users (2 of ...
CK36
Sep 03, 2025Guide
I've received correspondence via email from the Netgear Community Team with a firmware file to upload to my router to potentially correct this problem. Just to be ultracautious, how can I be sure this actually came from Netgear?
- FURRYe38Sep 03, 2025Guru - Experienced User
Only NG and set FW to be auto pushed to users routers. Nobody else.
Any user with NETGEAR Expert is a NG employee.
- TonyWuSep 14, 2025Aspirant
Hi CK36,
I 'm NTGR Product Manerger Tony. I will take over RS280 now.
My colleage Richard should have notify you about this info.I will provide another trial FW for you to debug this issue.
