Dummy001
Jul 01, 2026Tutor
RS100 Email Logs
I've been practically all over the Advanced Tab and subsections and cannot find where to set this up. The Help section in the Logs subsection does state "Click Send Log to send the log file to your e...
- Jul 02, 2026
Hello Dummy001 (no, you are absolutley not - far to many users never look into the online documentation)
Not a Nightawk RS router owner or user here. Have looked over the RS100 User Manual - and have not spotted any indications of this feature.
Looking a little bit further on "bigger" models User Manuals, like the
https://www.downloads.netgear.com/files/GDC/RS200/RS200_RS150_UM_EN.pdf , starting from p.65 one can find a this section:
Set up security event email notifications
The router can email you its logs of router activity. The log records router activity and security events such as attempts to access blocked sites or services. To set up email notifications:
ADVANCED>Security >E-mail. The E-mail page displays.===
The https://www.downloads.netgear.com/files/GDC/RS90/RS100-90-70_UM_EN.pdf does not show this feature, so best guess is: This feature is not available on the RS100,
Looks to me this section on the device online help does not completely removed for these "smaller" models for simplicity.
In case you are a "new" to the RS100, and you own the RS100 for less than three months - you are entitled for 90 days of complimentary technical support for the installation of your Nighthawk RS100 router, which begins from the date of purchase (== the product registration date) - contact Netgear Support via https://my.netgear.com/ and ask if this impression is correct.
-Kurt
Dummy001
Jul 02, 2026Tutor
Just wanted to say that this wasn't my 1st Netgear router. That was a R6220 which did have this email ability. I figured since this was a newer router that ability would still be in place.
I looked over the RS200 instructions you put out here and THAT looks like my R6220. Bummer. I thought this email logs deal was standard. I should have researched it a little further before purchasing.
I'm good with it though. It's set up and running, practically out of the box, just minor static IP's made and that's about it.
BTW: That was an AWESOME write up for an answer I have EVER received on a forum EVER. The closest to a response like this was from a bunch of technical guys on a Dodge site trying to help me diagnose an issue on our mini van. Keep it up!!
Thanks again Kurt!
