Dummy001
Jul 01, 2026Tutor
RS100 Email Logs
I've been practically all over the Advanced Tab and subsections and cannot find where to set this up. The Help section in the Logs subsection does state "Click Send Log to send the log file to your e...
- Jul 02, 2026
Hello Dummy001 (no, you are absolutley not - far to many users never look into the online documentation)
Not a Nightawk RS router owner or user here. Have looked over the RS100 User Manual - and have not spotted any indications of this feature.
Looking a little bit further on "bigger" models User Manuals, like the
https://www.downloads.netgear.com/files/GDC/RS200/RS200_RS150_UM_EN.pdf , starting from p.65 one can find a this section:
Set up security event email notifications
The router can email you its logs of router activity. The log records router activity and security events such as attempts to access blocked sites or services. To set up email notifications:
ADVANCED>Security >E-mail. The E-mail page displays.===
The https://www.downloads.netgear.com/files/GDC/RS90/RS100-90-70_UM_EN.pdf does not show this feature, so best guess is: This feature is not available on the RS100,
Looks to me this section on the device online help does not completely removed for these "smaller" models for simplicity.
In case you are a "new" to the RS100, and you own the RS100 for less than three months - you are entitled for 90 days of complimentary technical support for the installation of your Nighthawk RS100 router, which begins from the date of purchase (== the product registration date) - contact Netgear Support via https://my.netgear.com/ and ask if this impression is correct.
-Kurt
Jul 02, 2026Guru - Experienced User
Do you have Protection Engine being seen on the RS web page at all?
Dummy001
Jul 02, 2026Tutor
Yep. The engine is on.
- FURRYe38Jul 03, 2026Guru - Experienced User
Ok, this should help prevent most or "some" of attacks being seen in the logs from the WAN side. IF enabled, the port scans are marked as stealth instead of closed and if scans are performed on the WAN side, the results for those scans should be nothing seen and the scanner will move on. You can check your router at gibson research site and sheildsup test there with PE enabled vs disabled to see the differences.
I presume for most LAN side services or devices like Google and other IoT items, maybe seen as attacks by the system however are known scan for results by those services or devices and are just being logged by the system.
