Dummy001
Jul 01, 2026Tutor
RS100 Email Logs
I've been practically all over the Advanced Tab and subsections and cannot find where to set this up. The Help section in the Logs subsection does state "Click Send Log to send the log file to your e...
- Jul 02, 2026
Hello Dummy001 (no, you are absolutley not - far to many users never look into the online documentation)
Not a Nightawk RS router owner or user here. Have looked over the RS100 User Manual - and have not spotted any indications of this feature.
Looking a little bit further on "bigger" models User Manuals, like the
https://www.downloads.netgear.com/files/GDC/RS200/RS200_RS150_UM_EN.pdf , starting from p.65 one can find a this section:
Set up security event email notifications
The router can email you its logs of router activity. The log records router activity and security events such as attempts to access blocked sites or services. To set up email notifications:
ADVANCED>Security >E-mail. The E-mail page displays.===
The https://www.downloads.netgear.com/files/GDC/RS90/RS100-90-70_UM_EN.pdf does not show this feature, so best guess is: This feature is not available on the RS100,
Looks to me this section on the device online help does not completely removed for these "smaller" models for simplicity.
In case you are a "new" to the RS100, and you own the RS100 for less than three months - you are entitled for 90 days of complimentary technical support for the installation of your Nighthawk RS100 router, which begins from the date of purchase (== the product registration date) - contact Netgear Support via https://my.netgear.com/ and ask if this impression is correct.
-Kurt
HappyCat
Jul 02, 2026Luminary
The original post mentioned setting up the router to automatically send copies of the router log via email. On my ancient Netgear router, this is actually in two different places in the Advanced tab of the web interface:
Have you looked at these menu items in the RS100 to confirm that there are no similar entries?
schumaku
Jul 02, 2026Guru - Experienced User
HappyCat wrote:Have you looked at these menu items in the RS100 to confirm that there are no similar entries?
Dear FURRYe38, It's moot to discuss - this feature exists in the RS100 (and RS90, RS70, ...) online help system only. It does not exist in the user manual, too. Carelessly copied from the bigger models, after playing the typical consumer product "feature removal" game on "less expensive" models, why ever. "They pay less, so they have to accept certain fetures removed".
