vinoureux
May 20, 2025Follower
RS100 wifi schedule
Upgrading from an old Netgear router I would like to setup a WIFI schedule. WIth the old router it was straight forward to set times during which the Wifi was simply shut off. With the RS100 I do no...
May 23, 2025Guru - Experienced User
If it's not seen anywhere in the User Manual or in the routers web page, then that feature may not be available.
