Ricgonzalez14
Apr 13, 2026Aspirant
RS140 Previously configured device does not connect to the Wi-Fi network.
Hi, I have my company laptop and it ran out of battery while connected to my company's VPN. It also uses Cisco Anny Connect. After recharging, it won't connect to the Wi-Fi network with my RS140 rout...
CrimpOn
Apr 13, 2026Guru - Experienced User
Will the laptop connect to any other WiFi network? such as...
- Guest WiFi on the RS140?
- Hot Spot from a cell phone?
Does the RS140 have any features enabled which regulate device connection, such as
- Access Control
- Smart Parental Controls
- Armor
Ricgonzalez14
Yes, it connects to another network (mobile, work Wi-Fi, Ethernet cable to the router). I don't have guest network, Armor, Parental Control, or Access Control enabled.
