Ricgonzalez14
Apr 13, 2026Aspirant
RS140 Previously configured device does not connect to the Wi-Fi network.
Hi, I have my company laptop and it ran out of battery while connected to my company's VPN. It also uses Cisco Anny Connect. After recharging, it won't connect to the Wi-Fi network with my RS140 rout...
Apr 14, 2026Guru - Experienced User
Might even check with the work IT department to see if there's any known issues with that happening.
If you hardwire in the laptop, will it connect?
Might also be worth creating a guest network, and see if it connects to that.
