ahhinsean
Mar 03, 2025Aspirant
RS200 Random Disconnect
Hello Guys, I am currently facing an annoying issue about Nighthawk RS200. My firmware is V1.0.1.74 My PC is wired connection directly to the router and my phone connect to the router wireless. T...
ahhinsean
My Modem is HUAWEI OptiXstar HN8250Ts-20.
I changed my Router to 192.168.110.1 from 192.168.1.1 because I have contacted the local reseller support and they told me to try change the Gateway IP and test.
Mar 03, 2025Guru - Experienced User
Does the internet LED on the RS Router turn AMBER when this happens?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
Try option #2 first...
