joshfedo
Oct 06, 2024Initiate
RS280 - Rebooting kills wifi radios when VLAN tag group is enabled
I got the RS280 (A router sold by Costco similar to RS300) setup and running well but i'm running into a consistent issue with the WIFI radios not enabling on boot. I had to enable a VLAN tag group o...
Oct 06, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended
I recommend opening up a support ticket on this and let NG know about this.
- BH_COct 06, 2024NETGEAR Expert
Thanks for reaching out to us. I will ask our support team to reach out to you. I think we will need to get your settings and maybe some logs to look into it.
