BKAmputee
Jan 28, 2025Aspirant
RS280S LAN port stops working, reboot fixes it
The LAN port stopped working on my new RS280S last night. It is connected to an unmanaged Ethernet switch. Rebooting the RS280S got it working again. I read Costco customer reviews and another person ...
BKAmputee
Jan 30, 2025Aspirant
It has only happened one time so far. If it happens again, I will try bypassing the unmanaged switch.
Jan 30, 2025Guru - Experienced User
What brand and model# is this switch?
What kind of CAT# cables are being used?
- BKAmputeeJan 30, 2025AspirantIt is a TP-Link TL-SG108, cat 6 cable.
- FURRYe38Jan 30, 2025Guru - Experienced User
Can't recommend that mfr. You might give NGs GS108 series a try if it happens again.
Good Luck.- BKAmputeeJan 30, 2025AspirantNever had any problems like this with the old router, Nighthawk X4S R7800.
How would the unmanaged switch cause the RS280 lan port to lock up, with Wi-Fi still working? It is interesting that rebooting only the RS280 made the lan port start working again.
