BKAmputee
Jan 28, 2025Aspirant
RS280S LAN port stops working, reboot fixes it
The LAN port stopped working on my new RS280S last night. It is connected to an unmanaged Ethernet switch. Rebooting the RS280S got it working again. I read Costco customer reviews and another person ...
BKAmputee
Jan 30, 2025Aspirant
Never had any problems like this with the old router, Nighthawk X4S R7800.
How would the unmanaged switch cause the RS280 lan port to lock up, with Wi-Fi still working? It is interesting that rebooting only the RS280 made the lan port start working again.
Jan 30, 2025Guru - Experienced User
Will need to test the router with out the switch being connected. Anything could happen with 3rd party branded switches or cabling.
Is protection engine enabled on the routers web page under Advanced tab/Security?
Let us know if it happens again with out the switch.
- BKAmputeeJan 30, 2025AspirantProtection was enabled when this happened. But nothing was logged. I have now turned it off.
- FURRYe38Jan 30, 2025Guru - Experienced User
Ok, ya this could be another item. Is the version is still below 1.0.0.2112?
- BKAmputeeJan 30, 2025Aspirant1.0.1.60
Is that the FW version? Sorry meant to check for the PE version...
- BKAmputeeJan 30, 2025AspirantProtection Engine Version
2.2.214.4/1.0.0.2112 - FURRYe38Jan 30, 2025Guru - Experienced User
Ok. Lets try it disabled though was supposed to be resolved after PE was updated or shouldn't see issues that PE caused with lower version.
Let us know how it goes with it disabled. If it happens again, please try with out the switch connected.
