loadii
Jun 07, 2026Aspirant
rs300 - guest and iot
just got a rs300. it is in AP mode. the main network works fine. created a guest network on wifi 5g using wpa2 and wpa3. the ssid randomly shows up and when it does clients can’t join. also crea...
- Jun 10, 2026
updating to the latest firmware fixed the issue. thank you.
CrimpOn
Jun 07, 2026Guru - Experienced User
It might be worth updating to the current firmware. The release notes mention WiFi stability and IoT issues:
