loadii's avatar
loadii
rs300 - guest and iot
just got a rs300.  it is in AP mode.  the main network works fine.  created a guest network on wifi 5g using wpa2 and wpa3.  the ssid randomly shows up and when it does clients can’t join.  also crea...
  • loadii's avatar
    Jun 10, 2026
    updating to the latest firmware fixed the issue.  thank you.
