Greeny173
Dec 03, 2025Aspirant
RS300 & Brother Printer
I just recently replace my old NETGEAR router for the RS300. Installation did not go very well at first. After getting my ISP involved we got everything working (TVs, Telephone, and Alarm system) b...
- Dec 07, 2025
StehenB and CrimpOn, I found out one of the problem that was causing my installation situation was my printer cable. I purchased another one from Best Buy and after hooking it up, the installation problem went smoothly. I appreciate the assistance from both of you. Be safe and have a Happy Holidays!!
CrimpOn
Dec 03, 2025Guru - Experienced User
Does the printer have the same IP address on the RS300 that it had on the previous WiFi router?
Greeny173
To be truthful, I can't remember, but will do a deep dive to find out. The printer and the router have the same i.p address and show connection successful.
