Greeny173
Dec 03, 2025Aspirant
RS300 & Brother Printer
I just recently replace my old NETGEAR router for the RS300. Installation did not go very well at first. After getting my ISP involved we got everything working (TVs, Telephone, and Alarm system) b...
- Dec 07, 2025
StehenB and CrimpOn, I found out one of the problem that was causing my installation situation was my printer cable. I purchased another one from Best Buy and after hooking it up, the installation problem went smoothly. I appreciate the assistance from both of you. Be safe and have a Happy Holidays!!
Dec 03, 2025Guru - Experienced User
Greeny173 wrote:My Brother MFC-895DW connected right up to my SSID and inside my router login it shows up on my wireless devices. But it will not print,
Did you try uninstalling and reinstalling the printer software on your PC
Greeny173
Yes, I removed the software and reinstalled it on my printer and then removed the printer on my router login and reinstalled it. I worked with a technician from Brother and he walked me through steps to get my printer working and eventually said it comes down to the router.
- Greeny173Dec 04, 2025Aspirant
I misspoke!! I never got the software to get past finding the machine on the setup. Instead I inputted the SSID and ip. Then I went back and attempted to find the machine to get the software to continue installing. Nothing. Stuck at that step.
- CrimpOnDec 04, 2025Guru - Experienced User
When the printer was installed, did this step work correctly?
This is from the user manual:
https://download.brother.com/welcome/doc100736/cv_mfc690dw_use_qsg_c.pdf
and the printer appears on the router list of Attached Devices with an IP address?
- StephenBDec 05, 2025Guru - Experienced User
Also, did you do a complete reinstall of the printer software from here?
Since you know the IP address from the router's attached device list, you can also try adding back the printer using these steps:
- https://sscs.uchicago.edu/add-network-printer-windows10
