belmont1154
Apr 23, 2026Aspirant
RS300 & CityFibre - IDNet
Hello,
Can’t seem to find conclusive evidence if the Netgear Nighthawk RS300 BE9300 will work with IDNet on a CityFibre connection.
IDNet mentions VLAN 911 tagging but posts on the web seem to suggest the Netgear VLAN tagging implementation doesn’t cover the WAN port.
Any feedback greatly appreciated.
thanks
1 Reply
Most ISP's either supply you with an ONT or a gateway to convert from fibre to ethernet. I haven't seen one that doesn't work.
I'd just buy from somewhere with a decent return policy in case you can't get it working.
