belmont1154
Apr 23, 2026Aspirant
RS300 & CityFibre - IDNet
Hello, Can’t seem to find conclusive evidence if the Netgear Nighthawk RS300 BE9300 will work with IDNet on a CityFibre connection. IDNet mentions VLAN 911 tagging but posts on the web see...
Apr 23, 2026Guru - Experienced User
Most ISP's either supply you with an ONT or a gateway to convert from fibre to ethernet. I haven't seen one that doesn't work.
I'd just buy from somewhere with a decent return policy in case you can't get it working.
schumaku
Every Netgear Router ever released has this feature. It was introduced in the Netgear world - by ZyXEL (the OEM of Netgear's first router) manufactured in their Hsinchu many decades ago, whe I was young...
Even ISP Provided media devices and ONT sometimes require setting a VLAN for the "Internet" a configuration on place by default.
FMI RT*M Set up a bridge for a VLAN tag group, p.97 ff.
Adjust the default Internet config to use VLAN 911.
