giubeca
Apr 05, 2026Aspirant
RS300, firmware 1.0.6.16; Ethernet Settings
I'd like to configure the port aggregation to connect a switch to the port 1 and 2. Following the user manual on page 99, on the page ADVANCED>AdvancedSetup>EthernetSettings the port aggregation is d...
ella067thompson
Apr 06, 2026Aspirant
Hello, You can’t use port aggregation on ports that have VLAN enabled. Keep Port 1 for your ISP VLAN, and aggregate Ports 2 and 3 to your switch instead.
