giubeca
Apr 05, 2026Aspirant
RS300, firmware 1.0.6.16; Ethernet Settings
I'd like to configure the port aggregation to connect a switch to the port 1 and 2. Following the user manual on page 99, on the page ADVANCED>AdvancedSetup>EthernetSettings the port aggregation is d...
Apr 06, 2026Guru - Experienced User
giubeca wrote:But I need the VLAN configuration to connect my ISP; how have I to do?
Do you need this for internet access? Or are you using it for an IPTV service? If so, is the IPTV device connected to the switch?
Is the switch a gigabit switch? Or does it support multigig?
ella067thompson wrote:aggregate Ports 2 and 3 to your switch instead.
Can't be done with the RS300, it only supports local LAN aggregation on ports 1 and 2.
