hexcei's avatar
hexcei
Guide
Sep 10, 2024
RS300 Firmware Version 1.0.0.50 - No Internet
Wondering if anyone has any ideas.    I manually updated to FW 1.0.0.50 from 1.0.0.38 to see if it resolved a issue I was having with MSFT Teams calling since moving to this router. (It will discon...
  • FURRYe38's avatar
    Sep 10, 2024
    Try a power cycle of the RS and ISP modem/ONT after FW was updated?
    Maybe a factory reset and setup from scratch as well?
    What is the Mfr and model# of the Internet Service Providers modem/ONT or switch in the basement that the NG router is connected too?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
