johnnyboy98
Jun 28, 2024Aspirant
Rs300 internet not working on virgin hub 5 in modem mode
I've just got the rs300 and when I've connected the cable to my hub 5 that is in modem mode the rs300 will not connect the indicator light shows orange but when I move the cable to another port it wor...
johnnyboy98
Hi
Ye I'm using a cat 7 cable and I've turned the virgin hub on and off and still not working, as I say when I move it to another port on the virgin hub it works fine. I'll give it another try in the order you've said and see what happens.
Thanks john
Thanks john
