johnnyboy98
Jun 28, 2024Aspirant
Rs300 internet not working on virgin hub 5 in modem mode
I've just got the rs300 and when I've connected the cable to my hub 5 that is in modem mode the rs300 will not connect the indicator light shows orange but when I move the cable to another port it wor...
michaelkenward
Jun 29, 2024Guru - Experienced User
Did you find this?
Hub 5 in modem mode - Virgin Media Community - 5474880
Different router, but similar issue.
More here!
virgin hub 5 in modem mode - Google Search
But you probably tried that.
At least Virgin offers a modem mode, unlike BT and its nasty HomeHub.
- johnnyboy98Jun 29, 2024AspirantHi
Thanks for the reply
Just had a look at the fourms and done all of that ,still getting this orange light, doesn't seem to like the 2.5g port on the virgin hub. I don't know if it's some sort of a unknown bug on the rs300 also been disconnected randomly off the WiFi 7 band. I'll go on the virgin forums to see if it's an issue with their hub.
Agreed at least they let you put it into modem mode but their new hub5x doesn't have the feature yet.
Thanks again
John- FURRYe38Jul 02, 2024Guru - Experienced User
Any progress on this?
johnnyboy98 wrote:
Hi
Thanks again
John- johnnyboy98Jul 02, 2024AspirantHi
No still tried to connect to 2.5g port on the virgin router and nothing, tried a full reset on the rs300 and that didn't sort the problem as well. I've been I contact with netgear themselves and away to send it back for a full refund.
Thanks john
