flyaway1999
Oct 01, 2024Tutor
Rs300 keeps resetting admin account settings
Hi, theres an annoying issue I'd like to resolve. The first being that each time whether I have a power cycle or for some reason I need to unplug a cable anyways whatever the reason basically that cut...
flyaway1999
Oct 01, 2024Tutor
also why can i chose the 160mhz channel on 5g the highest there is is 64dfs????
- ShadowMario3Oct 02, 2024Luminary
flyaway1999 wrote:also why can i chose the 160mhz channel on 5g the highest there is is 64dfs????
I believe the idea is for you to choose channel 149 if you use 160MHz. If you choose anything else, that will overlap into the DFS channels, which is something I found out the hard way not too long ago on my RS700. I switches over to DFS chanel 100 with 160MHz to see how that goes. If I see myself get kicked off again, I'll need to switch over to channel 149 if I want to use 160 MHz.
- flyaway1999Oct 02, 2024Tutor
but i dont have a 149 i have these... which are 36,40,44,48,52dfs,56dfs,60dfs,64dfs. is this a firmware issue or something?? im in canada so these channels should be open...
