JamesL1979
Nov 19, 2024Apprentice
RS300 LAN Port Not Responding
I sometimes loose my internet connection from my LAN. DHCP seems to be working but the RS300 does not respond to ping and DNS does not respond, but it seems like routing is still happening cause I ca...
Dec 02, 2024Guru - Experienced User
Sounds like something on the PC adapter isn't right maybe.
Might give an Intel chip set a try if you can find something.
What windows version are you using?
JamesL1979
Dec 02, 2024Apprentice
What's supper weird is that I was able to do a remote capture on the pi via ssh, which I guess is a separate path on the PC, Windows 11.
