JamesL1979
Nov 19, 2024Apprentice
RS300 LAN Port Not Responding
I sometimes loose my internet connection from my LAN. DHCP seems to be working but the RS300 does not respond to ping and DNS does not respond, but it seems like routing is still happening cause I ca...
JamesL1979
Dec 04, 2024Apprentice
I am using the Realtek Gaming USB 2.5GbE Family Controller driver ver. 1156.15.20.327. I assume from here:
https://www.realtek.com/Download/List?cate_id=585
I have the following disabled in device manager->network adapters->Realtek Gaming USB 2.5GbE->properties->advanced:
Adaptive Link Speed
Advanced EEE
Battery Mode Link Speed (Not Speed Down)
Energy Efficient Ethernet
Gigabit Lite
Green Ethernet
idle power down restriction (only power down...)
idle Power Saving
Jumbo Frame
Large Send Offload (both ip4 and ip6)
Miscellaneous Transfer Settings
NS Offload
Priority VLAN
Wake on....
WOL & Shutdown Link Speed (Not Speed Down)
Dec 16, 2024Guru - Experienced User
Any progress on this? I presume this maybe the solution you posted?
Adaptive Link Speed
Advanced EEE
Gigabit Lite
Green Ethernet
idle Power Saving
Jumbo Frame
NS Offload
Priority VLAN
Wake on....
- JamesL1979Dec 16, 2024Apprentice
No repro lately, not conclusive what the issue was, could be the Realtek USB adapter.
- FURRYe38Dec 16, 2024Guru - Experienced User
So still working up to this point after you made those changes?
Ya, seems so, but I'm not convinced unless I go back to the OG driver windows installed or reset to the defaults. It's working so I don't want to mess with it. I would like to modify the back panel bracket to shoe horn the Intel M.2 card back in.
