mzeazeas32
Jun 04, 2025Aspirant
RS300 not updating dynamic DNS
I have 2 Netgear routers on my private network, they are a R8000 and a RS300. Additionally I have 2 Hostnames purchased from NoIP.com. I can define either NoIP hostname in R8000 router, click 'Sh...
Jun 04, 2025Guru - Experienced User
Is the RS connected behind the R8000? This is a double NAT condition which may interfer with the RS updating services correctly.
You might try the RS router in place of where the R8000 router is and check.
