mzeazeas32
Jun 04, 2025Aspirant
RS300 not updating dynamic DNS
I have 2 Netgear routers on my private network, they are a R8000 and a RS300. Additionally I have 2 Hostnames purchased from NoIP.com. I can define either NoIP hostname in R8000 router, click 'Sh...
mzeazeas32
Have xfinity router/modem as primary, RS300 router is plugged into xfinity router, R8000 router is plugged into RS300 router - the RS300 router has a ton of definitions in it, reserved addresses, port forwarding, VPN , etc so I hesitant to do a factory reset.
It replaced the R8000 which had all of these definitions and working DDNS too, As long as I keep the R8000 up it's ok, can just use the hostname for external connections
Network
in IP address IP Range
xfinity modem/router Coax 10.0.0.1 ( 10.0.0.2 - 10.0.0.254)
RS300 router 10.0.0.155 192.168.0.1 (192.168.0.2 - 192.168.0.254)
R8000 router 192.168.0.200 192.168.25.1 (192.168.25.2 - 192.168.25.254)
Hope that helps
Question - does anyone have a RS300 with Dynamic DSN on with a hostname from NoIP.com where show status works?
Thanks
Jun 30, 2025Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
New: https://community.netgear.com/kb/en-orbi-knowledge-sharing/static-ip-address-configuration-for-ap-mode/2456256
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
mzeazeas32 wrote:Have xfinity router/modem as primary, RS300 router is plugged into xfinity router, R8000 router is plugged into RS300 router - the RS300 router has a ton of definitions in it, reserved addresses, port forwarding, VPN , etc so I hesitant to do a factory reset.
Network
