mzeazeas32
Jun 04, 2025Aspirant
RS300 not updating dynamic DNS
I have 2 Netgear routers on my private network, they are a R8000 and a RS300. Additionally I have 2 Hostnames purchased from NoIP.com. I can define either NoIP hostname in R8000 router, click 'Sh...
mzeazeas32
Jul 10, 2025Aspirant
While the DDNS Show Status on the RS300 Router failure is not resolved with the responses here I've created the following using one DDNS hostname
- added and configured No-IP DUC exe to my windows pc (in case I quit using R8000 router)
- activated DDNS in R8000 router to keep DDNS hostname current (in case my pc is down for an extended period of time - redundancy)
- activated DDNS in RS300 router then regenerated VPN packages
- downloaded windows and android zip files and unpacked them
- copied windows files to C:\Program Files\OpenVPN\config, started OpenVPN and connected successfully (OPENVPN-TUN on RS300 attached devices)
- emailed android file to myself, opened on my cellphone, imported into OpenVPN and connected successfully, disconnected, closed wifi and connected successfully again
In conclusion, I have an configuration that works for me, many thanks to all who offered info and advice, BC_C if you have a updated img you want tested pm me
