hexcei
Jul 11, 2024Guide
RS300 Region Incorrect
Hi, Just a quick question. I live in the continental US (WI). The region in the UI of the RS300 says CANADA and is greyed out and cannot be changed. When I got the router first thing was a manua...
- Jul 11, 2024
OK, if you purchased it from NETGEAR.com then I don't need to see the giftbox.
So that should be a mistake on the shipment, you can contact our customer support (1-866-534-9377) to replace it with a new one. If you run into problems with the support, please send me your case number through private message and I will look into it.
I'm sorry about the mistake.
