butchjma
Jul 19, 2024Tutor
RS300 Samsung S24 Ultra pic text problem
My wife has a Samsung S24 Ultra connected using wifi to my newly acquired Nighthawk RS300. Text messaging works fine except when dealing with sending/receiving pictures. Will not upload or download...
butchjma
Jul 19, 2024Tutor
Firmware is the latest, ending in 038 I believe. It is currently not connected.
I have Glofiber as ISP with a NOKIA Model# XS-010X-Q modem, never had Fiber before so I guess it is the modem.
I am using Ugreen Cat 8 between the modem and the RS300. I don't recall but I do believe smart connect was enabled.
Jul 19, 2024Guru - Experienced User
Wondering if you disabled Smart Connect on the RS if that would change anything.
Also try putting this one phones IP address it gets from the router into the routers DMZ. See if picture messages come thru...Disable the DMZ after testing this.
- butchjmaJul 19, 2024Tutor
I have to get ready for work but will try that tomorrow morning and see what happens. BTW, my iPhone 14 PRO was very happy with the new router. I will get back to ya tomorrow on this.
Thanks for the idea.
Oscar
Just a quick side note. I did disable wifi 7 on her phone couple days ago and that did not solve the issue.
