butchjma
Jul 19, 2024Tutor
RS300 Samsung S24 Ultra pic text problem
My wife has a Samsung S24 Ultra connected using wifi to my newly acquired Nighthawk RS300. Text messaging works fine except when dealing with sending/receiving pictures. Will not upload or download...
butchjma
Jul 19, 2024Tutor
It was fine with the ISP provided router. Just wanted to stop renting from GloFiber. I believe the problem is with the router itself.
ShadowMario3
Jul 19, 2024Luminary
That is odd, could be an incorrect setting on the router. Do you have wi-fi calling enabled? Found out that was my issue the whole time, and turning it off fixed the issue with not receiving images.
- butchjmaJul 19, 2024TutorWifi calling was/is turned off
