The-Ark
Jul 04, 2024Guide
RS300 Unable to turn of QOS function
I am unable to turn on QOS function Already try to reset multiple times~ Still unable to turn on the QOS After speed test~ The QOS fail to activate
Jul 05, 2024Guru - Experienced User
My understanding (I'm not netgear) is that the QoS settings were removed. They weren't recommended at speeds over 250mbps anyway. If you log into the debug page (routers IP address/debug.htm) there's an option to enable it in the GUI. But it might be buggy or not fully implemented.
