kacall
Oct 03, 2024Tutor
RS300 Wifi 7 router
Recently purchased a Netgear RS300 Wifi 7 router. Wireless works great, unable to get my lan wired devices to work. I have tried 2 Netgear unmanaged switches and neither switch can get IP addresses...
Oct 03, 2024Guru - Experienced User
What model# are these switches?
What port are you connecting the switch to on the back of the RS Router?
What CAT# LAN cables are you using? CAT6 is recommended.
Do ethernet connected devices connect and work while connected directly to the back of the RS router?
I have a had a GS308, GS808 and a HP 1400 series managed switch connected to my RS600 and all work fine.
