kacall
Oct 03, 2024Tutor
RS300 Wifi 7 router
Recently purchased a Netgear RS300 Wifi 7 router. Wireless works great, unable to get my lan wired devices to work. I have tried 2 Netgear unmanaged switches and neither switch can get IP addresses...
michaelkenward
Oct 03, 2024Guru - Experienced User
kacall wrote:
I have tried 2 Netgear unmanaged switches and neither switch can get IP addresses to send to the hard wired devices from this router.
Unmanaged switches don't "get IP addresses". That is in the hands of the router.
Where do the switches sit in the network? They should be after the router. They then work with the router which assigns IP addresses.
Just another user with time on their hands.
- kacallOct 03, 2024Tutor
Michael,
I actually only use 1 Netgear 16port (GS316) switch. But for troubleshooting purposes,
I disconnected that switch and used a Netgear 8 port switch that I have on hand. It reacted the same way.
NO IP addresses will come through the switches. On the router you have 2 ports to use for normal LAN, and I have tried both and same reaction. So here is my configuration, Cable Modem, connected to RS300, Switch connected to RS300 via ethernet port.
Kevin
Michael,
I know that unmanaged switches do not get IP addresses, but they should let the router send them through to the devices. That's how it worked before I replaced the Cable Modem and the router on Tuesday.
This was all caused because my old Netgear router died after 8 long years.
Kevin
- michaelkenwardOct 03, 2024Guru - Experienced User
I'd look for another cause the behaviour you see.
Replacing the cable modem is a clue.
The RS300 is a router. If you have a new cable modem, maybe that is getting in the way.
What is that cable modem?
