JaJacek
Nov 02, 2024Aspirant
RS300 WIFI VPN
Using the local network of the wifi network in the netgear rs300 router, it is not possible to connect to another network using VPN IPSec on the fortinet device. After connecting with an ethernet cab...
Nov 07, 2024Guru - Experienced User
Something you might ask Fortinet about regarding there product.
The RS can connect to other host routers, double NAT condition. Maybe on different sub nets. May not be supported on the RS router.
- JaJacekNov 07, 2024AspirantThis only applies to forticlient vpn on android. In another network with another router this client works.
