ThorPan
Sep 30, 2025Aspirant
RS500 — Nighthawk BE12000 WiFi 7 Tri-Band Router Protection Engine Problems
Hi, Unfortunately, I'm 2 weeks past the measly 90 days of support for my RS500 - Nighthawk BE12000 router, so I'm posting here instead, trying to prompt Netgear to actually create firmware that w...
HappyCat
Oct 09, 2025Virtuoso
You are correct. Not everyone has the option to Edit or Move a post. Using this Happy Cat login, those options do not appear for me.
No clue what would cause Netgear to have the Forum software not allow users to edit their own post.
