coolwifi
Dec 08, 2025Virtuoso
RS500 - Higher ping times to router than my previous router R6700AX
I am consistently getting ping times of 3ms or higher from a nearby laptop to the router over wifi. The same ping times with my previous router R6700AX is only 1 ms or lower from the same location an...
- Dec 08, 2025
Can't find v22.150 anywhere to try?
Just tested my RS600 here and getting same thing on a AX210 adapter PC on 5Ghz:
I had to disable Smart Connect to force my adapter to 5Ghz as it kept connecting at 6Ghz. I didn't test 6Ghz.
I'll pass this to NG and see if this is something acceptable and if there is any suggestions or information. May need some tuning in FW.
