elliottgaryusa
Nov 16, 2025Tutor
RS500 cannot connect older printer
Is there a way to connect an older printer using WPA-PSK and not downgrade the whole network?
- Nov 17, 2025
elliottgaryusa wrote:
HP Officejet Pro 8600
That does have an ethernet port, and switching to that would be your best option.
elliottgaryusa
Nov 17, 2025Tutor
- FURRYe38Nov 17, 2025Guru - Experienced User
IF the printer has ethernet port, connect the printer to the router using ethernet.
If you have WiFI and WPA3 in the mix, older devices have problems if WPA3 is on the signal.
- StephenBNov 17, 2025Guru - Experienced User
