Mr_CSIM
Jan 19, 2025Tutor
RS500 drops wifi devices and ping issues
Have devices dropping wifi for no reason. I noticed while it is actively dropping, it will timeout while pinging its IP from another device on the network (not via wifi or rear wired). Pinging 19...
Jan 20, 2025Guru - Experienced User
A couple things.
1. not sure what you mean by showing canada. You don't have any photos attached to see what you're talking about.
2. In AP mode, the router is a simple switch. Something else on your network is handling dhcp/nat/routing.
3. You said its "not via wifi or wired". So how is it connected or what are you referring to with this? This isn't very clear what you mean or whats going on.
