FedVin
Jan 13, 2025Aspirant
RS500 has network dropout for both wired and wireless devices
I have a Netgear RS500 Wifi7 router I purchased a few months ago. It is connected through a TP-Link 5 port 2.5G ethernet switch (TL-SG105S-M2). So I have wired connections and wifi connections. I am ...
- Jan 14, 2025
Ok. NG is making tuning adjustments to the PE feature. Hopefully next FW update or an PE update will make it better so you can turn it back ON.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jan 13, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is Protection Engine enabled on the RS routers web page? Under Advanced Tab/Administration/Security. If so, disable this feature, apply the change and reboot the router.
FedVin
THanks for the response. FOrgot to include the info you asked for...
What Firmware version is currently loaded? - V1.0.1.60
GUI Language Version - V1.0.0.449
Protection Engine Version - 2.2.214.4/1.0.0.2061
NetGear cable modem CM3000
One Cat8 3 ft cable to TP-Link, then come Cat6, Cat8 cables for the 4 wired devices
Protection Engine under Advanced-Security is ON
Unchecked Protection Engine and applied.
Powercycled the Router, waited 1 minute
Checking Wifi via Wifi Sweetspots app
- FedVinJan 13, 2025Aspirant
General question of debugging these issues. What applications are there to assist in capturing network connectivity over time for post review? On my iPhone, I found Wifi Sweetspots, but for some reason I cannot save the file. Any others (Windows or iOS) that would assist here? Thanks!
- FURRYe38Jan 13, 2025Guru - Experienced User
One Cat8 3 ft cable to TP-Link, then come Cat6, Cat8 cables for the 4 wired devicesWhat is the TP-Link?
Protection Engine under Advanced-Security is ONUnchecked Protection Engine and applied.
Checking Wifi via Wifi Sweetspots appLet see how it runs with out PE enabled.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message- FedVinJan 14, 2025Aspirant
Well I believe turning of Protection Engine was it. I have used Wifi Sweetspots about 6-8 times for ~5-8 minutes each time on my iPhone and other than 1 time when I saw a drop from ~650 to ~100, it was pretty steady between 850 and 500. There was one odd instance when monitoring that it went to zero but some for some reason, the Wifi router itself rebooted?! Anyways, thanks.
- FURRYe38Jan 14, 2025Guru - Experienced User
Enjoy. 📡
