FedVin
Jan 13, 2025Aspirant
RS500 has network dropout for both wired and wireless devices
I have a Netgear RS500 Wifi7 router I purchased a few months ago. It is connected through a TP-Link 5 port 2.5G ethernet switch (TL-SG105S-M2). So I have wired connections and wifi connections. I am ...
- Jan 14, 2025
Ok. NG is making tuning adjustments to the PE feature. Hopefully next FW update or an PE update will make it better so you can turn it back ON.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
FedVin
Jan 14, 2025Aspirant
Well I believe turning of Protection Engine was it. I have used Wifi Sweetspots about 6-8 times for ~5-8 minutes each time on my iPhone and other than 1 time when I saw a drop from ~650 to ~100, it was pretty steady between 850 and 500. There was one odd instance when monitoring that it went to zero but some for some reason, the Wifi router itself rebooted?! Anyways, thanks.
Jan 14, 2025Guru - Experienced User
Enjoy. 📡
- BH_CJan 17, 2025NETGEAR Expert
The updated Proteciton Engine has been pushed to all routers in the field, it should fix the internet access issue.
If your Protection Engine version is still below 1.0.0.2112 or you still experienced initernet access issue with the new engine, please let me know. Thanks.
