coolwifi
Mar 28, 2026Virtuoso
RS500 hidden advanced setting enables MLO
Not sure why Netgear chose to hide the advanced wireless settings revealed through the F12 browser display link mod. I can confirm that only the MLO setting works in my RS500 router when toggled ON, ...
CrimpOn
Mar 28, 2026Guru - Experienced User
can you post a link (URL) to information about this F12 mod?
Yes, the Community Forum "paste" function has been broken since the first of the year (12 weeks). Netgear said a fix was coming soon, but that was on Jan 20.
There is a work-around which involves putting the image on a cloud storage platform and then using the Camera Icon "From image URL" option.
coolwifi
Found the OP here and dug around to find the additonal hidden settings.
https://www.reddit.com/r/NETGEAR/comments/1rwwplt/mlo_hidden_in_router_settings_and_can_be_turned_on/
