coolwifi
Mar 28, 2026Virtuoso
RS500 hidden advanced setting enables MLO
Not sure why Netgear chose to hide the advanced wireless settings revealed through the F12 browser display link mod. I can confirm that only the MLO setting works in my RS500 router when toggled ON, ...
Mar 29, 2026Guru - Experienced User
NG keeps the MLO feature hidden until such time as they have fully developed MLO for the RS series. They are working on it and it's not ready as of yet. No idea when. I'll keep checking.
So the WEB UI code is make to hide the UI feature as it is a placeholder only for when the actual MLO feature IS ready to be deployed and enabled by NG.
My two Intel BE200 series work with MLO with my Orbi BE series MLO supporting systems.
Also my Iphone 17 is working with MLO as well.
- baybreezegMar 29, 2026Guide
The Intel BE200 only support the eMLSR version of MLO. This means they can't use multiple frequencies at the same time, and only have the version of ML that can "sense" which one is open to swap to dynamically.
